Battery Type Settings on the GPSMAP 65/s and GPSMAP 66s/st
When using alkaline, NiMH, or lithium batteries in the GPSMAP® 65, 65s, 66s, or 66st outdoor handheld, it may be necessary to change the battery type settings.
NOTE: When using the Garmin NiMH Battery Pack the AA Battery Type options are overridden and removed from the System menu (see Re-charging the Garmin Ni-MH Battery Pack in a compatible Outdoor Handheld for more details)
- Press Menu twice to access the Main Menu
- Select Setup
- Select System
- Select AA Battery Type
- Select Alkaline, Lithium, Traditional NiMH, or Precharged NiMH
