Using Helm in the ActiveCaptain® App with Discontinued Chartplotters
The Helm function works on Discontinued Chartplotters using the current Garmin ActiveCaptain® app. The now discontinued stand-alone Helm app is no longer downloadable on a mobile device. See the following list of chartplotters that do not require an ActiveCaptain card to use the Helm feature. The chartplotter needs to be registered and have current software.
Compatible Discontinued Series
GPSMAP® 1040 chartplotter
GPSMAP® 840 chartplotter
GPSMAP® 741 chartplotter
GPSMAP® 547 chartplotter
Set up Communications On Chartplotter
Power on the GPSMAP® chartplotter, select Settings > Communications > Wireless Devices > turn on Wireless Network if necessary, and rename and create a password.
Set up the Helm Feature on the Chartplotter
Select Settings > Communications > Wireless Devices > Helm from the main page. Choose the Helm viewing preference to use
From the Smart Device (phone or tablet)
Open the ActiveCaptain app on the smart device. Click on the blue Connect to Garmin Wi-Fi > select the chartplotter's network > answer Connect when the message displays.
Once connected to the ActiveCaptain app, the main page populates the Helm icon is now selectable.
Controlling the GPSMAP using Helm is accomplished by touching the smart device screen and selecting the appropriate push button key. To access the button menu, press the six square button in the upper right-hand corner of the display—the button menu screen functions as the push buttons on the chartplotter.
See examples below of some ActiveCaptain views using Helm along with the selectable push button keys.
Active Captain Main Menu: The GPSMAP device is ready to be selected GPSMAP ready to be controlled by Helm
Select Helm icon Select the GPSMAP to be controlled Touch the screen or the 6 squares
After touching the handheld screen, Helm with GPSMAP "HOME" screen and Helm with GPSMAP "Chart" screen and
selectable push buttons appear selectable push buttons activated selectable push buttons activated
NOTE: The selectable pushbuttons will time-out and disappear if they are not being used.
