Changes in BaseCamp™ When Using BaseStation Mode
When using BaseStation mode, BaseCamp™ software will have different functions such as:
  • In BaseCamp™, the folder listed under the device will show 'BaseStation' (instead of Mass Storage).
  • Data cannot be sent to the connected device from BaseCamp™ while it is in BaseStation mode.
    • In BaseCamp™ data stored in the Mass Storage section of the associated handheld device will be inaccessible while utilizing BaseStation (for example: previously created Waypoints, Routes, Tracks, Pictures and Mapping, such as Topo 100k, will be inaccessible).
    • Waypoints, Routes and Tracks from the BaseStation folder can be transferred to other BaseCamp™ folders or lists while using BaseStation mode.
      • Updated track data will not be reflected in other folders or lists until the most up to date track information is transferred.
  • When the BaseStation folder is selected the map in BaseCamp™ will be updated automatically with the current positions of the handheld device and its available contacts.
  • Data will only be available if the BaseCamp™ is able to communicate with the connected handheld device.
  • Information will not be available for devices that do not have a GPS or GNSS signal.
  • Connected devices can only receive and display data from devices compatible with each other (for example: Astro® 320 handheld with DC™ 40 collars, Rino® radio with Rino radio, and Alpha® dog tracking handheld with Alpha handheld and TT™ 15 collars).
    • Multiple connected devices will have multiple BaseStation folders.
    • Only one BaseStation folder may be displayed at a time.
Related
