User Data Limitations of the Tread Series
When Sending or Creating Files for the Tread® GPS Navigator and all Models in the Tread® Series, Keep in Mind the Following Limitations:
  • Unlimited GPX files1
  • Waypoints -  These points are stops along your route.
    • Maximum of 1,000 waypoints on the Tread®, Tread® - Base Edition, and Tread Textron devices
      • If storage is enabled using the Tread® app there is no limit to the number of waypoints that can be stored. For steps on enabling storage in the Tread app see .
    • Maximum of 10,000 waypoints on the Tread® 2 Series GPS navigators
      • If storage is enabled using the Tread app there is no limit to the number of waypoints that can be stored. For steps on enabling storage in the Tread app see Enable Storage on the Tread App.
    • Maximum of 8,500 waypoints on the Tread® - Overland Edition, Tread® - SxS Edition, Tread® XL - Overland Edition, Arctic Cat G8 Display, Kawasaki RIDGE® 8" Tread® Display, and Kawasaki Teryx® H2 10" Tread® Display devices
    • Maximum of 8,500 waypoints on the Tread® XL - Baja Chase Edition and Tread® XL - Baja Race Edition
      • If storage is enabled using the Tread app there is no limit to the number of waypoints that can be stored. For steps on enabling storage in the Tread app see .
    • Waypoints are typically announced as stops. Shaping points are used to guide the route without necessarily being announced, influencing the path taken by the device.
  • Shaping Points - These points allow you to "shape" a custom route to your preference on an automotive device.
    • You may insert a shaping point (up to 125 per route) into a custom route to direct your device to use a specific road in navigating to your destination.
  • Unlimited geocaches1
  • Unlimited routes1
    • Maximum of 200 waypoints per route.
  • Unlimited saved tracks1
    • Maximum of 10,000 points per track on the Tread, Tread - Base Edition, and Tread Textron devices
    • Maximum of 100,000 points per track on the Tread 2 Series
    • Maximum of 250,000 points per track on the Tread - Overland Edition, Tread - SxS Edition, Tread® XL - Baja Chase Edition, Tread XL - Baja Race Edition, Tread XL - Overland Edition, Arctic Cat G8 Display, Kawasaki RIDGE 8" Tread Display, and Kawasaki Teryx H2 10" Tread Display devices
      • A software update may be required to get the full maximum
  • 2,000 archive tracks
Each GPX file can contain a mixture of waypoints, geocaches, routes, and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on the device. When utilizing routes, only 50 points can be used for on-road navigation.
1 Contingent on the fact that the device has enough storage space
Related
