Tracks and Travel History on a Camper 895, RV 895, Camper 1095, or RV 1095
Travel History stores data recorded while you are traveling. This data is used in features such as myTrends, TracBack, Track Recorder and Tracker on the following devices:
  • Camper 895 caravan and motorhome sat nav
  • Camper 1095 caravan and motorhome sat nav
  • RV 895 RV navigator
  • RV 1095 RV navigator
Travel History Features:
When Travel History is enabled, the data collected will allow the following features to operate as described below:
myTrends
When you travel regularly to saved destinations, your device will, over time, begin to learn where you’re going without any input from you. Your device may begin to offer a suggested route.
TracBack
The TracBack feature retrieves the most recent segment of your movement.
You can view your recent track back to the previous location, or save it as a turn-by-turn route
View Track
To follow a track back on the last segment to the point you came from
1. From the main screen tap on Apps
RV 895 Apps
2. Tap on TracBack
    • Tap on Navigation on the left if TracBack is not shown
RV 895 TracBack
3. Your recent track appears on the map.
    • Tap on Go
TracBack 1
    • Follow the track
RV 895 TracBack Go on track 1
NOTE: This will be a track to follow on the map. It will not have turn-by-turn directions. To have the device guide you with directions, see the steps to Save Track as a Route below.
You can save your recent track as a route, which you can navigate later using the Route Planner
RV 895 Apps
2. Tap on TracBack
RV 895 TracBack
    • Tap on the wrench in the upper left corner to save the track as a route
TracBack Wrench
4. Tap on Save as Route
5. Enter a name you want to call the route then tap on Done
6. The new route will be saved in Route Planner
Track Recorder
Track Recorder records your path. When you start tracking, your device logs your location and updates the track line.
NOTE: Your track will be recorded as unsaved automatically when Travel History is enabled
RV 895 Apps
2. Tap on Track Recorder
    • Tap on Navigation on the left if Track Recorder is not shown
RV 895 Track Recorder
3. Tap on Start to begin recording the track you are currently traveling on
RV 895 Start Track Recorder
4. Tapping on Split will allow you to add multiple segments to the overall track
    • Tap on Stop to end track recording
RV 895 Track Recorder Stop
 5. Tap on Save or Discard
    • Saved tracks will appear in the Tracks app. (See steps below to view saved tracks)
RV 895 Save Track
Tracks
The Tracks app stores your saved and unsaved tracks
NOTE: Travel History must be turned on to record unsaved tracks, which will then be deleted after 6 months. Unsaved tracks can be saved within 6 months in the Tracks app. (See steps below to enable Travel History)
Saved Tracks
RV 895 Apps
2. Tap on the Tracks app
  • Tap on Navigation on the left if Tracks is not shown
RV 895 Tracks
3. To view a list of Saved Tracks tap on the right-hand tab RV 895 Saved Tracks
RV 895 Saved Tracks List
NOTE: If desired, tap on the wrenchRV 895 Wrench icon icon in the upper-left to Share, Delete or Import a track
4. Select a track and tap on the icon RV 895 Info icon to view the route and information
    • Tap Go to begin following the track from Start to Finish or Finish to Start
    • NOTE: This will be a track to follow on the map. It will not have turn-by-turn directions. To have the device guide you with directions, see the Editing Options in the next step #5 below to Convert to a Route.
RV 895 Track Saved Info
5. If desired, tap on the wrench iconRV 895 Wrench icon to edit the saved track
Editing Options:
RV 895 Track Saved Wrench
Unsaved Tracks
RV 895 Apps
RV 895 Tracks
3. To view a list of Unsaved Tracks tap on the tab RV 895 Calendar icon 1
  • On the Unsaved Tracks list, tap on the wrenchRV 895 Wrench iconfor additional options to Share or Clear Travel History
  • To view a particular track, select a listed date/time of the track
4. View the selected track on the map
  • Tap on the wrench while viewing the track to Share, Save Track, Save as Route and to view the Elevation Profile
RV 895 Unsaved Track.
View All Travel History/Unsaved Tracks on the Map
Travel History will record unsaved tracks that can be displayed on the map. Travel History is essentially an "electronic breadcrumb" trail that shows you where you've been whenever the device is turned on and has acquired satellites.
  • This feature requires enabling Travel History recording. (See Enable Travel History steps in the dropdown below)
  • To view Unsaved Tracks on the map, you must enable the map layer. See the steps linked here: Hiding or Showing the Trip Log
To Enable or Disable Travel History
  1. From the main screen tap on Settings
  2. Tap on Navigation
  3. Scroll down and tap on Travel History
  4. One of two messages will appear as shown below:
    • To Save Travel History (Enable):
Tap No to disallow, or Yes to allow.
Travel History 1
    • To Disable Travel History:
Tap No to continue saving Travel History, or Yes to disable it.
Disable Travel History 1
Travel History Enabled:
Travel History Enabled button
Travel History Disabled:
Travel History Disabled button
To Clear Travel History
Clears your Travel History data used for the myTrends, Where I've Been, Saved & Unsaved tracks used in the features described above:
  4. Tap on Yes to clear all travel history data
Related
