Select the following link to download the app: Spotify Connect IQ app.
Select the
button.
If prompted, sign in to your Garmin account.
Select your device to download the app.
Acknowledge any app permission requests.
The message should indicate that the app will be installed during the next sync. If this does not occur automatically, below are options to sync your device:
To sync via Bluetooth: Be in range of your paired smartphone, then press and hold the power button to access the Controls Menu. Select
to sync.
To sync via Wi-Fi: Be in range of your Wi-Fi network, then press and hold the power button to access the Controls Menu. Select
to sync.
To sync using Garmin Express: Connect the device using supplied power/data cable to a computer. Open Garmin Express. A sync will automatically occur once the device is detected.
Once the sync is complete, the Spotify app will be installed on your device. You are ready to move to Step 2.
