Sharing Saved Places/Routes From an Automotive Device
You can import and export GPX files like waypoints and routes you have created with other Garmin users in two ways: through the Garmin Drive™ app or with a memory card.
To Share a Route using the Garmin Drive App
1. Touch Apps or the apps icon DriveCam 76 Apps icon 1
2. Touch Route Planner
3. Touch the wrench in the top left corner
4. Touch Share
5. Touch Garmin Drive
6. Select the routes you want to share
7. Touch Done
8. Touch OK
9. Open the Garmin Drive app on your phone
10. Touch Share
11. Follow the on-screen instructions to share the .gpx files
12. The receiving Garmin user can then open the file with the Garmin Drive app
13. Touch Send in the Garmin Drive app
The trip will now be found in Route Planner on the receiving device.
To Share a Saved Location with the Garmin Drive App
1. Touch Where To?
2. Touch Saved
3. Touch the menu button in the top left corner
4. Touch Share
6. Select the waypoints you want to share
7. Touch Done
8. Touch OK
10. Touch Share
11. Follow the on-screen instructions to share the .gpx files via email
The waypoint will now be found in your Saved places on the receiving device.
To Share a Route using a Memory Card
1. Insert a compatible microSD card into the memory card slot on your Garmin navigator
2. Touch Apps
3. Touch Route Planner
4. Touch the wrench in the top left corner
5. Touch Share
6. Touch Memory Card
7. Select the route you want to share
8. Select Done
To Share a Saved Location using a Memory Card
2. Touch Where To?
3. Touch Saved
4. Touch the menu button in the top left corner
5. Touch Share
7. Select the waypoints you want to share
8. Touch Done
Sharing Saved Files as a Way of Backing Up Your Saved Locations / Routes
It may also be possible to use the Share features (described above) as a way of backing up your device's collection of saved locations / routes (as GPX files) to your compatible smartphone.
NOTE:
  • Large file sizes shared to and from the device may lead to long processing times.
  • The device or Drive app may not operate normally during the processing of a large file export or import and there may not be an easy way to cancel the sharing request.
  • Allowing the needed time for the import or export to complete is necessary if using this feature.
Files can be sent back to the device with the Garmin Drive app, see: Sending a Location, Coordinates or GPX File through the Garmin Drive App
