Switching Between a Marine and Automotive Charts on a GPSMAP Handheld Device
To switch from Marine charts to the Automotive maps on a GPSMAP handheld device follow this path:
NOTE: There may be subtle differences in terminology/titles/menu options between the various GPSMAP handheld devices.
From the Main Menu:
Select Map
Press MENU
Select Setup Map
Select Orientation
Select Automotive Mode
Select Map Information, press ENTER to select the Automotive map
Press QUIT
Press MENU
Select Setup Marine
Go to Marine Chart Mode, press ENTER
Turn off Marine Chart Mode
To save a Custom profile:
From the Main Menu
Select Setup > Profiles
Select Create New Profile > OK
To Edit the Profile:
From the Main Menu
Select Setup
Select a Profile
Select Edit Name
Enter New Name
Select Done
