Replacement Watch Bands for Garmin Approach S60
A replacement band can be ordered on Garmin’s website to update the look of your watch or replace a band.
The watch bands that fit your Approach S60 can be found using the link below and expanding the + Bands line.
If the band has broken within 12 months of purchase, please contact our Product Support team and include your Garmin Connect account email address and the watch’s serial number (printed on the back of the watch or where the band attaches to the watch body).
Finding Bands at Garmin.com
- Hover over the Sports & Fitness menu at the top Garmin.com.
- Select a product type.
- Select your watch from the list.
- Click on Accessories.
- Click on Bands.
You will now see a list of compatible bands for your watch.
If your watch is not listed here, you may need to use the search box located in the upper right-hand corner of the Garmin.com home page.
Replacing the Approach S60 Watch Band
Replacing the QuickFit band on your Approach S60 takes just a few steps. QuickFit bands are designed to be changed very quickly, and without tools.
Removing the Band
- Locate the latch on the band near the housing of the watch.
- Pull the latch away from the housing of the watch and lift the band from the pin
Replacing the Band
- Pull down on the latch on the band
- Place the band on the pin and release the latch
You have successfully changes your QuickFit band.
