Protect the Tread® Group Ride Radio Mount from Harsh Outdoor Elements
Protecting the Tread® Group Ride Radio Mount from the elements will help increase its life.
You can Help Protect the Mount by Following the Tips Listed Below:
  • Keep pins dry and covered with the included weather cap
    • The included weather cap is attached to the power cable as seen below
  • Wire power for the mount to a switched power source to provide power to the mount only when the vehicle is powered on
  • Apply dielectric grease to the pins to create a thin protective coating on the surface of the pins
  • If water does get into the connection area, blow it out with compressed/canned air
  • Mount the device behind fairing (windshield), if available
These steps will help protect your device and accessories from harsh weather elements.
