Sending a SPOT Configuration to the Earthmate PN-60w
You must perform an Export to your PN-60w whenever changes are made to your device settings within your SPOT account.  This transfers any changes to your PN-60w.
  1. Connect your PN-60w to your PC.
  2. Login to your SPOT account at www.findmespot.com
  3. Click the My Spot Devices tab.
  4. Under Your SPOT Devices choose Export to PN-60w.
  5. Click Export Now.
  6. The current configuration will transfer to the PN-60w.
    Note: If you have not already done so, you will be prompted to download and install the DeLorme Send to GPS plugin for your web browser. See Related Content for instructions to troubleshoot the plugin if the transfer fails after installation.
  7. If you have not already paired the PN-60w and the SPOT device, see Related Content for instruction.
Related
