How the Tacx NEO Bike Series Fans Respond During Use
The fan speed adjustments on the Tacx NEO Bike Series can be set in the Tacx Training app. You may notice that with the fan speed set to Level: High and Controlled by: Heart Rate, the fan speed responds to your heart rate level by either increasing or decreasing in speed or by stopping completely.
How Do Speed/Heart Rate/Power Values Affect the Fan Speed?
The descriptions below help lay out the specifics of how the fan speed will respond to different user inputs depending on the setting. The fan speed is linear and will not switch between low, medium, and high. Depending on which setting you have the fan speed set to, low/medium/high, there is a minimum and max value for each input of Speed, Power, and Heart Rate. Below the minimum value, the fan remains off (or goes to minimum speed). Above the maximum value, the fan remains at the max fan speed. Chose one of the options below to reveal details.
Power
When you choose for fan speed to be controlled by the power you output during training, the fan speed will adjust on a linear scale based on the following parameters.
  • Fan Speed High: 50 – 250 watts
  • Fan Speed Medium: 100 – 400 watts
  • Fan Speed Low: 100 – 500 watts
Speed
When you choose for fan speed to be controlled by the speed at which you ride during training, the fan speed will adjust on a linear scale based on the following parameters.
  • Fan Speed High: 5 – 30 km/h
  • Fan Speed Medium: 10 – 35 km/h
  • Fan Speed Low: 15 – 50 km/h
Heart Rate
When you choose for fan speed to be controlled by your heart rate during training, the fan speed will adjust on a linear scale based on the following parameters.
  • Fan Speed High: 80 – 130 bpm
  • Fan Speed Medium: 100 – 160 bpm
  • Fan Speed Low: 120 – 180 bpm
Fixed
When you choose for fan speed to be fixed, the fan speed will depend on which of the four fan speeds you choose in the app; Off, Low, Medium, or High. In this Fixed mode, the fan speed will not adjust during your ride in response to a change in power, speed, or heart rate.
How to Adjust Fan Speed Settings in the Tacx Training App
  1. Open the Tacx Training app
  2. Connect the NEO Bike (for instructions see: Connecting your Tacx Smart Trainer to the Tacx Training App).
  3. Select Set up "Tacx Smart Bike".
    Arrow pointing to Set up Tacx trainer
  4. Select Trainer Settings.
  5. Select Fan.
  6. Choose your preferred Fan Settings configuration.
Example View
Series of fan settings available in the Tacx Training App
Related
