How Do I Stop the Squeaking Coming From Rally XC Pedals?
The squeaking originates from the interface between the cleat and the metal wear plate on either side of the Rally XC pedal. To eliminate the squeaking, clean the surface of the silver wear plate on both sides of the pedal and apply a dry lube containing Teflon or something similar. Allow the lube to dry prior to use.
