Navionics Boating: Following a Saved Track in Reverse
You can follow saved tracks by doing the following:
  1. Access your tracks from Menu > Tracks.
  2. Select the track you want from there by tapping on the name and you will see it appear on the screen.
  3. Tap the < or X button in the upper-left of the screen to back out to the main map.
Your yellow track line will show on the map. You can then follow this same track on the screen of your device by relying on your GPS to navigate along the track line in the reverse direction.
