Features of the Tacx Blue Motion Basic Trainer
Below are details regarding the features of the Tacx® Blue Motion trainer that will influence your indoor cycling experience.
Flywheel
The Blue Motion is equipped with a 1,6kg (3.52 lbs.) flywheel. The weight of the flywheel in combination with the rotational speed creates a large inertia. This inertia results in a smooth cycling experience.
Resistance Level
Blue Motion comes with a lever allowing you to control the amount of resistance the trainer can apply to the rear wheel while you pedal. Blue Motion can simulate up to 950 watts of power using the lever.
Blue motion resistance lever
App Compatibility
Using Garmin® Bluetooth Speed and Cadence sensors will allow you to experience virtual power in many different cycling apps such as the Tacx Training™ app.
