NOTE: Your watch must be able to connect to a previously connected Wi-Fi network. You will also need your smartphone that is paired to your device through the Garmin Connect app.
Swipe the screen on the watch to the Music widget.
Press and hold the menu button (bottom right) to access the music menu.
Select Music Providers.
Select Deezer.
Return to the Music widget and select the music note icon.
Select Deezer to manage music.
The watch will attempt to connect to your Wi-Fi network.
Once connected, the watch will display a message to Open Garmin Connect on Phone. Select Next.
Acknowledge the message on the phone which will take you to Deezer. Depending on whether you have an account, the login process will be as follows:
Existing Deezer users: Enter your login details and select Log In.
New to Deezer: Tap the Register here link and follow the steps to create your account.
If prompted, enter credit card details to complete the process. Proceed to Step 2.
