Rino 520HCx or 530HCx Time and Date are Incorrect
We have fixed a problem with the date and/or time being wrong on the Garmin. A software update is required to fix the issue.
What happens if I don't update the software?
- The date and/or time determined by the GPS will be wrong
- Position, velocity, navigation, and all other functionality not dependent on date and/or time will continue to work normally
How do I update the software?
You can download the latest software using WebUpdater found here.
Important: You may have to install a GPS Chipset first from additional updates:
- If there are no updates available, select check for additional updates.
- If there are updates available, install those first, then select check for additional updates.
How do I verify the update installed?
You can verify the updates have installed properly by disconnecting the Rino from the computer then rebooting it.
- Go to Main Menu
- Select Setup
- Select System
- Select Option Menu
(top of the page)
- Select Software Version
The software version should read 3.40 and GPS software version 3.20. If the information does not appear updated try the install again.
