On-screen Error Messages on a LiveScope™ Scanning Sonar
If a component of the LiveScope™ scanning sonar system disconnects during use, the connected chartplotter will display an error message, and the GLS™ 10 sonar module will display an LED pattern. After acknowledging the error message, the message and LED light pattern may change. See the table below to determine which error message corresponds with which disconnected component.
Disconnected componentError messageGLS 10 LED behavior
Power cableA Panoptix Transducer is Disconnected
After acknowledgment: Sonar Service Off
No light
Garmin Marine Network cableA Panoptix Transducer is Disconnected LED flashes red continuously
Transducer cableA Transducer is disconnected. The sonar has been turned off.LED flashes red three times
Reconnect the indicated component to resolve the error message. See Troubleshooting Marine Sonar Modules if the message recurs.
Related
