International Filing with FltPlan
FltPlan provides FULL flight planning coverage for all of the U.S. and select airports in the Bahamas, Bermuda, Canada, Mexico and Caribbean.
For some airports you can create the flight plan using FltPlan.com, but to actually file the flight plan you must provide a copy of your ICAO flight plan to the local authorities before departing.
You can get a copy of the ICAO Format flight plan to give the local authority by using the link on top of the NavLog labeled ICAO FPL.
You can also use QUICK INFO to get basic international flight planning information, including airport info, weather, distances, and approximate ETEs. For international flight plan filing that is not available with FltPlan, please see the Garmin Pilot app.
