How to Replace the Approach S70 - 47mm Watch Bands
Garmin offers replaceable watch bands to update the look of your Approach® S70 - 47mm, or replace a worn or damaged watch band. The Approach® S70 - 47mm is compatible with QuickFit 22 Watch Bands. Here is what you will need to replace the watch band:
- A clean workspace
- The Approach® S70 - 47mm
- Precision flathead screwdriver
- Replacement band
When you are ready to replace your watch band follow the steps on removing the watch band or jump straight to the replacing the band itself if you already know how to remove the bands.
