Replacing the VHF Antenna on a T 5 mini or TT15 mini Collar
The VHF antenna used on the T 5 mini and TT™ 15 mini collars is user-replaceable. It is suggested that before replacing the antenna you ensure the area of the collar where the antenna is connected is free of dirt, water, and debris.
If necessary you can purchase a replacement antenna on Garmin.com.
The cover to the collar is comprised of 2 pieces, and in order to replace the antenna it is only necessary to remove the smaller one of the pieces.
- Remove the 4 screws (1) carefully from the L-shaped cover over the end of the VHF antenna and note where the one screw that is shorter belongs
- Remove the L-shaped cover
- Remove the final Phillips screw to release the VHF antenna
- Loop the antenna guide around the collar strap and thread the new VHF antenna through the guide. This helps to keep the antenna pointed up.
- Replace the screw securing the VHF antenna to the black plate
- Replace the L-shaped cover over the VHF antenna
- Replace the 4 screws on the L-shaped cover, replacing the short screw in the correct location
