Fusion MS-BB300 Manual Software Updates
Fusion MS-BB300 Marine Black Box software version 2.0.3520
as of October 16, 2017
Download (5.29 MB)
View installation instructions
Notes:
  • This firmware release also contains updates for DAB+ accessories and NRX remote controls.
  • NRX Series Remote 1.02.71
  • DAB+ Module C6D28C3
  • USB Flash Drive: Ensure the USB Flash Drive is formatted to FAT32.
  • Accessory software updates (MS-NRX Series/MS-DAB100A): Once the stereo is updated the connected accessory MUST be updated from the update menu to be compatible with your Fusion Entertainment System.
Change History
Changes made from version to 1.1:
  • Fixed memory leak causing shutdown (DAB)
  • Updated DAB version
  • Updated NRX version
  • General bug fixes and improvements
Installation Instructions
  1. Insert a blank USB flash drive formatted in FAT32 with a capacity of at least 4gb and no larger than 32gb into the PC/laptop
  2. Download the FusionMS-300MarineBlackBox update file to the PC/laptop and open it
  3. Drag the Update folder onto the USB flash drive
    • The Update folder should now be the only folder on the USB flash drive
  4. Connect the USB flash drive to the USB Port of the stereo
  5. On the stereo, select Menu > Settings > Update > Update Software
  6. The DAB+ module and remotes can now be updated from the update menu if required
