My DriveTrack is Showing Red Grid Lines on the Map
If you have loaded Garmin HuntView™ Plus mapping to your Garmin DriveTrack™ GPS navigator you may see red grid lines at various zoom levels. These red grid lines are both the BLM's Principle Meridian and Baseline lines (6 miles by 6 miles = 36sq mi) and the smaller Township and Range boundaries (lines, typically 1sq mi) that are part of the HuntView Topo image. If needed, you can disable the HuntView Topo image which will remove the lines from your map screen.
Disabling Garmin HuntView Plus - HuntView Topo map image
  1. From the DriveTrack navigator Main Menu, Tap Settings
  2. Tap Map & Vehicle
  3. Tap Configure Maps
  4. On the map entry for the "HuntView Topo (for your state)", Tap the Check Mark box on the left to disable
