Wireless Map and Software Update Instructions
A wireless connection is an easy way to keep the software and maps on your navigator up to date. To ensure a smooth and successful process, we recommend:
Connect to a home high-speed internet (Fiber, Cable, DSL, etc.) with a stable Wi-Fi network.
Keep the device plugged into a power source.
Do not interrupt the update process. A software update may take a few minutes, while a map update may take several hours.
Before you begin, let's talk about some things to avoid:
- Wi-Fi connections in a workplace may not be successful. Companies may restrict downloads on their network.
- Connections with data caps or restrictions should not be used due to the size of a map update.
- Slower connections (satellite, fixed wireless, dial-up, etc.) and mobile broadband (MiFi, AirCard, mobile hotspot, cell phone tethering, etc.) should not be used.
- Not all captive portals will be compatible with Garmin devices. See Using a Wi-Fi Device on a Captive Portal for additional information.
- See Not Enough Free Space for a Wireless Update if your device states there is not enough space for the wireless update.
Watch this Brief Video to Learn About Wi-Fi Connections for Updates:
Select from the Following Videos to Learn about Map and Software Updates for Your Device:
Camper 795 caravan and motorhome sat nav
RV 795 RV navigator
CamperCam 795 motorhome sat nav with built-in dash cam
RVcam 795 RV navigator with built-in dash cam
Camper 890 and Camper 1090 caravan and motorhome sat navs
RV 890 and RV 1090 RV navigators
Camper 895 and Camper 1095 caravan and motorhome sat navs
RV 895 and RV 1095 RV navigators
NOTE: The device will be unusable until the updates complete.
See Troubleshooting Wireless Updates on an Automotive Device if the device encounters any problems with the wireless update.
You may also update your device by using the Garmin Express software installed on a compatible Mac or Windows computer. See Updating Automotive Maps and Software with Garmin Express.
NOTE: Not all devices come preloaded and/or are compatible with the maps below.
