How can I check if my aircraft is eligible for a Connext Satellite Service?
If your aircraft has one of the following devices on your system’s Line Replaceable Unit (LRU) list, then you are eligible for the Garmin Connected Services™ application program:
- A Garmin Satellite Receiver (GSR) 56, typically labeled as a GSR1.
- A Garmin Data Link (GDL®) 60 data transceiver.
A Garmin GDL 59 data transceiver for aircraft maintenance reporting.
- To see which service plans are available based on your aircraft and system combination, see the Connected-Cockpit Services page. For questions about your aircraft’s service capabilities, contact Garmin Aviation Product Support.
