Can Garmin Watches Broadcast Heart Rate Data?
Many Garmin® watches can broadcast heart rate, to verify compatibility and to find steps on how to broadcast refer to your owner's manual.
Many third-party apps and devices may require the heart rate to be broadcast over Bluetooth® to receive a signal. Any Garmin device or sensor that broadcasts over Bluetooth will also broadcast over ANT+® wireless protocol whenever you enable broadcasting. For devices compatible with Bluetooth broadcasting see the list below.
Watches That Broadcast Heart Rate Data via Bluetooth
  • Approach® S50
  • Approach® S70 | Approach® S70 - TaylorMade Edition
  • D2™ Air
  • D2™ Air X10
  • D2™ Mach 1 |D2™ Mach 1 Pro
  • Descent™ G1 | Descent™ G1 Solar | Decent™ G1 Solar - Ocean Edition
  • Descent™ G2
  • Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
  • Descent™ Mk3 | Descent™ Mk3i
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition
  • epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner® 55
  • Forerunner® 165 | Forerunner® 165 Music
  • Forerunner® 245 | Forerunner® 245 Music
  • Forerunner® 255 | Forerunner® 255 Music | Forerunner® 255S | Forerunner® 255S Music
  • Forerunner® 265 | Forerunner® 265S
  • Forerunner® 570
  • Forerunner® 745
  • Forerunner® 945 | Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Forerunner® 970
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
  • Instinct® 3 - AMOLED | Instinct® 3 - Solar
  • Instinct® 3 Tactical Edition - AMOLED | Instinct® 3 Tactical Edition - Solar
  • Instinct® E
  • Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • quatix® 6 | quatix® 6X Solar | quatix® 6 Titanium
  • quatix® 7 Pro | quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
  • tactix® 7 - AMOLED | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
  • tactix® 8 - AMOLED | tactix® 8 - Solar
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
  • Venu® 2 | Venu® 2S
  • Venu® 2 Plus
  • Venu® 3 | Venu® 3S
  • Venu® Sq 2 Music
  • Venu® X1
  • vívoactive® 5
  • vívoactive® 6
  • vívosmart® 5
Garmin Heart Rate Straps That Broadcast Data via Bluetooth
In addition to the above watches, the following heart rate monitor straps can also broadcast their signal via Bluetooth which is a common feature needed to transmit this data to third-party apps.
  • HRM-Dual™ monitor
  • HRM-Fit™ monitor
  • HRM-Pro™ monitor
  • HRM-Pro™ Plus monitor
  • HRM 200 monitor
  • HRM 600 monitor
ANT+ Concurrent Connectivity
If you need to pair a sensor to more than one device, we recommend pairing using ANT+ on the Garmin device to leave the Bluetooth® Low Energy (BLE) channel open for other devices. For steps on how to set your sensor connection type, see your owner's manual.
For more information on compatibility and pairing with third-party apps, we recommend visiting the app's help pages or contacting the developer of the app.
Related
