Updating Automotive Maps and Software with Garmin Express
Garmin Express™ is computer software used to download and install the latest version of maps and software to your device. Map Updates are released at least once per year.
See the videos and instructions below to install and use Garmin Express to update your device.
Map Updates - Map updates provide the latest changes to roads and locations on the map used by your navigation device.  The map files are large because they contain detailed information. These take longer to install.
Software Updates - Software updates make changes to the operating system files. These smaller files usually download in a few minutes.  Garmin Express may alert you to reboot your device after a software update. This may be required before the map update can be installed.
Current Map Version: 2026.30 (North America) as of November 05, 2025.
Current Map Version: 2026.30 (Europe) as of October 15, 2025.
Current Map Version: 2026.10 (Middle East and North Africa) as of July 30, 2025.
Current Map Version: 2026.10 (South America) as of May 7, 2025.
Watch One of Our Video Tutorials About Installing and Using Garmin Express
They are a quick and easy way to learn how to use Garmin Express.
Windows
Mac
Click on the Steps Below to Update your Automotive Device with Garmin Express:
If you already have Garmin Express installed on your computer, skip to step 2.
1. Download and Install Garmin Express
Before updating your device, you will need to download and install Garmin Express onto your computer. See How Do I Install Garmin Express?. If you don't have access to a computer, you can also update the device with Wi-Fi. See the owner's manual of your device for instructions.
NOTE: Only the Garmin DriveSmart™ 65 Traveler's Edition and Overlander® are compatible with Wi-Fi Updates.
Download Garmin Express Software for Windows
    • Windows 10 or newer
    • Microsoft .NET 4.7.2 (included in the download)
    • 1024 x 768 display
    • USB port
    • 1 GB RAM
    • High-speed Internet access (not for use with dial-up, mobile, or satellite connections)
    • Up to 20 GB free disk space
    • For users running Windows 8 or older, please download version 7 of Garmin Express for Windows.
Download Garmin Express Software for Mac
    • macOS 13 or newer
    • 1440 x 900 display
    • USB port
    • 1 GB RAM
    • For users running older macOS versions, please download 7.18.x of Garmin Express for Mac.
See the links below for help finding the download file on your computer:
2. Connect the Device to a Computer
Connect your Garmin device to the computer with the appropriate data USB cable.
Desktop:
usb cable plugged into desktop
Laptop:
usb cable plugged into laptop
Most devices come with a compatible data cable. See Types of USB Cables Used to Connect Automotive Devices to the Computer to find out what cable you need.
Touch Continue or allow the countdown to complete. Don't touch Cancel if the below message appears. Touching Cancel will require you to unplug the device and plug it in again.
usb connection detected prompt
The device needs to charge if it only shows a Garmin logo with the battery icon. Charge the device using the vehicle power cable or an AC Adapter. See Using Third-Party AC Chargers, Cables, and Other Accessories with Garmin Automotive Devices.
NOTE: It is recommended to place the device screen side down when it's plugged into the computer to reduce stress on the device’s USB port.
3. Launch Garmin Express
Garmin Express will launch during the installation.
To Open Garmin Express Manually:
Windows: Use one of the following three methods (examples from Windows 10 pictured).
  • Double-click the Express icon in the system tray:
garmin express icon
  • Search for Garmin Express in the Start menu:
garmin express icon
  • Double-click the desktop shortcut (if present):
garmin express icon
Mac: Launch Garmin Express from the Applications folder in Finder (example pictured from macOS 10.13.6). The location of the finder icon Finder icon may vary depending on the position of the Dock.
garmin express icon
4. Begin Updates
1. Click on your device. The green dot means Garmin Express recognizes the device
2. Click Add a Device and follow the on-screen steps to add a new device
Garmin Express Add a Device screen
3. A message may appear asking if you want to replace the first device if you're adding a second device of the same model.
Select Yes if this is a replacement device.
Select No if you have two devices of the same model.
similar device found prompt
Garmin Express will display the updates. Your device may have a software update available, a map update available, or both. You will have an option to “Update Software,” “Update Maps,” “Install,” or “Install All.” Each path begins with this selection.
NOTE: Your device may require a software update before installing a new map. In this case, the software update will be installed before returning you to this screen where you will then have the option to “Install All” or “Update Maps.”
4. Click Update Software, Update Maps, Install, or Install All
update software button
Clicking View Details allows you to see a list of available updates and install them individually.
Garmin recommends clicking the option in the blue button to ensure all updates are installed.
  • iOverlander updates can be installed by clicking Install All.
    • Only compatible with the Overlander®.
5. Read the notes and click Continue
important notes
Garmin Express will display the current progress.
update in progress
6. You may be prompted to restart your device if software updates are installed. Garmin Express will display instructions.
restart your device
7. Click Install All or Update Maps if you have a map update available.
install all option
8. Read the Terms and Conditions and click Accept
terms and conditions
9. Read the notes and click Continue
important notes
Garmin Express will display the Map Update progress.
updating maps
An “Updates complete” message will appear when the map update finishes.
up to date
Note: Disconnecting the device or shutting down the computer before the update completes will cause an error and may make the device unusable.
Space Issues When Installing Map Updates
Use a Memory Card (Recommended)- In situations where a Garmin device does not have sufficient internal storage space to load the full coverage of a City Navigator map update, Garmin Express allows the maps to be installed to a microSD/SD card.
When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, see the FAQ SD Memory Card Sizes for Automotive Devices.
Adding a memory card to a compatible device will help to give it enough storage space for the entire map. For more information about using a memory card for map updates, including SD card size requirements and instructions if Garmin Express does not offer a memory card option, see Garmin Express Prompts to "Use A Memory Card (Recommended)".
If you select Use a Memory Card, the card must be inserted into the device, not the computer. The map file will be deleted from the device's internal storage drive; therefore, the memory card must remain inside the device at all times both during and after the map update.
NOTE: You must install the full map for Voice Command to work.
If issues persist, see Garmin Express Only Offers Options to Contact Product Support or Use a Memory Card for additional steps.
Having Problems With Garmin Express?
Try These Helpful Troubleshooting Links:
