No AIS Targets on Garmin Device
When using an AIS device, if you are not seeing any targets, there are multiple things to check.
Check the AIS Status Light; for more information on the AIS Status Lights and what they mean, click here.
If the AIS is connected over NMEA 2000, check to see if it is appearing in the chartplotters device list. If the AIS does not appear, troubleshoot the NMEA 2000 network. For troubleshooting steps, click here.
On the chartplotter, select Settings > Communications > NMEA 2000 Setup > Device List
If the AIS is connected over NMEA 0183, ensure the Communication port setting on the chartplotter is set to NMEA High Speed
With the chartplotter powered ON, press the Home button
Choose Configure or Settings
Select Communications
Choose NMEA 0183 Setup
Choose Port Types
Choose the NMEA Input port that the receiver is connected to
Select NMEA High Speed
Ensure AIS is enabled on the chartplotter
Select Settings > Other Vessels > AIS > On
