Garmin Connect App GroupTrack Feature
GroupTrack allows you to keep track of other participants in your group using our LiveTrack™ software directly on the screen of a compatible device. Users will only be able to see another connection's location in relation to theirs. There are no interactive features available with GroupTrack.
List of Devices Compatible with GroupTrack
NOTE: Additional models that are compatible with Garmin® LiveTrack will be visible on a compatible GroupTrack device. In this scenario, a LiveTrack compatible device will display their location on a GroupTrack compatible device, however, they will not be able to see the positions of others.
Cycling Computers
  • Edge® 1000
  • Edge® 1030 | Edge® 1030 Plus
  • Edge® 1040 | Edge® 1040 Solar
  • Edge® 1050
  • Edge® 520 | Edge® 520 Plus
  • Edge® 530
  • Edge® 540 | Edge® 540 Solar
  • Edge® 820
  • Edge® 830
  • Edge® 840 | Edge® 840 Solar
  • Edge® Explore
  • Edge® Explore 2
  • Edge® Explore 820
Smartwatches
  • D2™ Delta | D2™ Delta PX | D2™ Delta S
  • D2™ Mach 1 | D2™ Mach 1 Pro
  • Descent™ Mk1
  • Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
  • Descent™ Mk3 | Descent™ Mk3i
  • Enduro™ 2
  • Enduro™ 3
  • fēnix® 5S | fēnix® 5 | fēnix® 5X
  • fēnix® 5S Plus | fēnix® 5 Plus | fēnix® 5X Plus
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner® 745
  • Forerunner® 935
  • Forerunner® 945
  • Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Forerunner® 970
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • tactix® Charlie
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
  • tactix® 7 - AMOLED Edition | tactix® 7 Standard Edition | tactix® 7 Pro Edition | tactix® 7 Pro Ballistics Edition
  • tactix® 8 - AMOLED | tactix® 8 - Solar
Wrist-Mounted GPS Navigator
  • Foretrex® 601
  • Foretrex® 701
  • Foretrex® 801
  • Foretrex® 901
What Are the Required Conditions to Use GroupTrack?
GroupTrack requires that certain conditions are met in order to view a participant on a compatible device.
  • You must be connected with the participant via Garmin Connect Connections.
  • The device must be paired and connected to a phone through the Garmin Connect™ app.
  • The phone needs to have a cell service signal.
  • You must have set up the LiveTrack feature within the Garmin Connect app.
  • You must have set up the GroupTrack feature within the Garmin Connect app (see steps below).
    • Some Garmin devices support starting the LiveTrack and GroupTrack session from the device itself, but the initial setup needs to be completed in the Garmin Connect app.
  • A Garmin Connect Connection needs to be added to the "Visible to" field of GroupTrack in the Garmin Connect app.
    • You can choose to be visible to all your Connections with a GroupTrack compatible device or send an invite to specific Connections using Invite Only.
  • The timed activity must be started in order for the position to be shared.
  • Smartwatches must be using a running or cycling activity-type.
  • You must be within range of your connections sharing this GroupTrack session (40km or 25mi).
For details specific to your model of device refer to your owner's manual.
How Do I Turn On GroupTrack?
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Safety and Tracking.
    • If you do not have this option, proceed to step 4.
  4. Select LiveTrack.
    • If prompted select I Consent. From here, LiveTrack supported devices will be listed.
  5. Select the 3 dots from the top right.
  6. Select Settings.
  7. Select GroupTrack.
How Frequently Does a Position Update During a GroupTrack Session?
A user's current position will be sent from their LiveTrack device to Garmin's network and display on a compatible GroupTrack device every 15-30 seconds, as long as a Bluetooth® and cellular connection are present.
How Does GroupTrack Work on a Garmin Watch?
When you have GroupTrack set up on your phone and are recording an activity with one of the compatible watches listed above, a notification will appear on the watch face when Connections are added to the GroupTrack:
data fields on a Forerunner watch showing a GroupTrack notification
To see your Connection's location on your device, you must have the map added as a Data Field. Refer to your owner's manual for instructions on adding data screens.
NOTE: It can take up to 5 minutes for Connections to appear on the map during an activity.
Map data field on a Forerunner watch showing connection's location
Your position will be indicated by the blue triangle while your Connections will appear as a colored shape with the first letter of their Garmin Connect username.
Related
