Alpha 10 Not Syncing or Staying Connected to the Garmin Explore App
If you are having trouble getting the Alpha® 10 or the Garmin Explore™ app to sync, or the device is not staying connected with the Explore app, there are a few things to look for.
  • Rebooting the smart phone and the Alpha 10 can resolve most connection issues.
  • Make sure you have a strong wireless internet connection when account syncing.
Troubleshooting Options
Check That the Bluetooth on the Alpha 10 is Turned On
  • The Phone Connected status icon should be viewed in the status bar next to the battery charge indicator.
  • Make sure Bluetooth is turned on. Select Setup on the Alpha 10, then Phone.
Confirm That You are Running the Latest Version of the Garmin Explore App
  • Check for updates to the Explore app in your phones app store.
Make Sure the Software on the Garmin Device is Up to Date
Check for and Install Any Available Updates for Your Phone
  • Consult your phone manufacturer for assistance as needed.
Miscellaneous Items to Check
  • Make sure that Airplane Mode is turned OFF on your mobile device.
  • Select Devices in the Explore app and verify that the Alpha 10 shows as Connected.
  • Make sure you are selecting the sync option you want:
    • The sync option in the Account section synchronizes the Explore app with the Explore website.
    • The sync option in the Devices section syncs the Explore app with the Alpha 10.
  • If the Explore app will sync with the Alpha 10 but not with your account on the Explore website, check that your phone has a wireless data connection.
  • Ensure the phone's Location Services are turned ON:
    • refer to your phones operating system documentation on enabling and disabling app Location Services
      Example on Android: Phone Settings > Apps > Explore app > Permissions > Location On
Full App Uninstall and Reinstall
If the previous steps did not correct the issue, it may be necessary to forget the Bluetooth pairing, clear the phone's cache of any hidden files, uninstall the app, reboot the phone, and re-install the Explore app.
  1. Select Forget Phone in the phone settings of the Alpha 10.
    1. Navigate to the Main Menu on the Alpha 10.
    2. Select Setup.
    3. Select Phone.
    4. Select Forget Phone.
    5. Select Yes.
  2. Forget/Remove the Alpha 10 in the Bluetooth settings of your phone or tablet.
    • Consult your phone operating system's documentation for assistance as needed.
  3. Clear the Explore app cache files and clear data (this step not necessary for iPhones).
    • Refer to your phones operating system documentation on clearing app hidden files caches.
      Example on Android: Phone Settings > Apps > Explore app > Storage > Clear Cache and also Clear Data
  4. Uninstall the Explore app.
    • See below for steps to uninstall the Explore app.
  5. Restart both the phone and Alpha 10.
  6. Download the Explore app, and try pairing and syncing again.
    • See below for steps to reinstall he Explore app.
To uninstall and reinstall the Garmin Explore app:
  1. Uninstall the Garmin Explore app from your mobile device.
    • Select your operating system below for instructions on how to uninstall an app. For further assistance, refer to your mobile device's user manual.
  2. Reinstall the Garmin Explore app from your mobile device's app store.
    App Store Icon Google Play Store Icon
