Receiving Traffic When Traveling to a Different Country
Your Garmin device has the ability to receive traffic when traveling to some other countries. See the requirements below for each traffic type.
NOTE: Not all Garmin automotive products are compatible with traffic. Check the material that came with your device or the device's owner's manual for traffic compatibility.
Live Traffic Through the dēzl™ App, Tread® App, or Garmin Drive™ App (Easiest Way)
See the articles below to check if your device is compatible:
To Receive Traffic in Another Country on Your Device:
For information on setting up dēzl™ App traffic or Garmin Drive™ App traffic, go to the Support Center and enter the product name or the serial number of your device. Once your device is selected, in Search for a solution... field, enter "Setting up Garmin Traffic".
Traffic with TA Cable, GTM Cable, or HD Traffic Mount:
You can use your GTM traffic receiver in another country if you had previously purchased a traffic subscription.
NOTE: Traffic subscription purchases have been turned off. Purchasing the traffic subscription is no longer available.
