Open the Garmin Connect app.
Select More.
Select Training & Planning.
Select Garmin Trails.
Scroll on the map to search trails in a specific region.
Swipe up from the bottom to see trail details.
Select a trail.
Select Send to Device.
Select your preferred device.
Using Garmin Trails
Access thousands of trails, and their ratings and reviews, through the Garmin Connect™ app or the Garmin Explore™ app, then send them directly to your compatible device so you can go offline and navigate with confidence with an active Garmin Connect+ or Outdoor Maps+ subscription.
Choose a topic below for more information.
What Devices Are Compatible?
Garmin Trails is compatible with Garmin devices that support courses. Refer to What Garmin Devices Are Compatible With Courses? for compatibility.
Where are Trails Available?
Trails can be found in the following regions:
Austria
Germany
Liechtenstein
Slovenia
Switzerland
United States
New trails in different regions will be added periodically.
How Do I Send a Trail to My Device?
Select your platform to reveal instructions.
From a web browser, sign into your Garmin Connect account.
Select
from the upper left corner to expand the menu navigation.
Select a trail.
- You can also select Filters to filter displayed trails by length, total ascent, rating, difficulty, trail type, or features.
Open the Garmin Express™ program and sync your device.
Open the Garmin Explore app.
Select
and the map layers will display on the page.
Select Garmin Trails under Map Details to show trails on the map.
You can also select
Tap
to return to the map, then scroll on the map to search trails in a specific region.
Tap a point on the map, then swipe up from the bottom to see a list of trails near the selected map point.
Select a trail.
Select
Save.
Select
Devices.
Select the device you wish to send the trail to.
Select
The sync icon has to be orange to manually perform a sync. If the icon is gray, this usually indicates a recent or upcoming sync.
Wait for the sync to complete.
When the sync is finished, the icon will change to gray and display the time of the last sync. The saved trail will then be available on the synced Garmin device.
Can I Add My Own Trails?
This option is not available with Garmin Trails.
How Do I Report an Issue With a Trail?
Select More.
Select a trail.
From the action options under the title, swipe and select Report Issue.
Select an issue category.
Fill out the form.
Select Report Issue.
Select
Select a trail.
Select
(bottom right of the trail information pane).
Select Report an issue.
Fill out the report feedback.
Select
You can also select
Tap
Tap a point on the map, then swipe up from the bottom to see a list of trails near the selected location.
Select a trail.
Select
Select what kind of issue you are reporting:
Trail description is missing important information.
Trail name could be improved.
Trail mapping needs to be corrected.
Trail is indefinitely closed.
Other
Fill out the form and select Report Issue.
Can I Suggest a Better Description for a Trail?
Select More.
Select a trail.
Scroll down to the trail description and select Suggest a description update.
Fill out the form.
Select Suggest Update.
Select
Select a trail.
Select
Select Suggest a Description Update.
Fill out the form.
Select
You can also select
Tap
Select a trail.
Enter your description for the trail, then select Submit.
How Do I Remove My Review?
Select More.
Select
in the top right corner.
Select My Trail Reviews.
Select
in the top right corner of the review you would like to delete.
Select Delete.
Confirm deletion.
Select
Select a trail.
Select
(top right of the trail information pane).
Select My Reviews.
Select Delete on the review you want to remove.
Select Delete to confirm. Once deleted this cannot be undone.
What Garmin Trails Features Are Available With a Subscription?
Feature | Garmin Connect Website | Garmin Connect App | Garmin Explore App | Subscription Required? |
Search for a Trail | X | X | X | No |
Add Trail Reviews/Pictures | X | X | No | |
Read Full Trail Details | X | X | X | No |
Read Trail Reviews | X | X | X | No |
Earn Badges | X | X | No | |
Report a Trail Issue | X | X | X | No |
Suggest a Trail Description Update | X | X | X | No |
Download Trails to a Device | X | X | X | Yes |
Customize Trails | X | X | Yes |
