Garmin Express Not Detecting Automotive Device on Newer macOS
For users of macOS Catalina 10.15 and higher, permission is required to allow devices to connect with the Garmin Express™ application. You may see a message Garmin Express would like to access files on a removable volume. An example is shown below.
Clicking OK will allow Garmin Express to recognize the device.
Clicking Don't Allow prevents Garmin Express from recognizing the device. This can be adjusted in the Security and Privacy settings on the computer if Don't Allow was accidentally selected.
NOTE: Some newer Mac computers may only have USB-C or Thunderbolt ports, which would require an adapter such as a USB-C to USB Adapter. Apple has a helpful support article that explains different USB types, how to identify them, and what adapters can be used: Identify the ports on your Mac and Adapters for the Thunderbolt 4, Thunderbolt 3, or USB-C port on your Mac.
See Automotive Device Not Detected by Garmin Express on a Mac if your Security and Privacy settings are set to allow Garmin Express to access files on a removable volume and your device is still not being recognized.
Adjusting the Security and Privacy Settings on macOS Catalina 10.15, macOS Big Sur 11, and macOS Monterey 12
1. Click the Apple Icon
2. Click System Preferences
3. Click Security & Privacy
4. Click the Privacy tab
5. Click Files and Folders
6. Click the box next to Removable Volumes for Garmin Express to add a checkmark
  • If Garmin Express is not listed in the privacy tab under Files and Folders, try creating a new Admin user on the Mac or try using another computer.
  • If this option does not appear after creating the new Admin user, the Mac may need to be serviced.
7. Click Quit Now if the message below appears. This message will only appear if Garmin Express is open or running in the background.
NOTE: You may have to restart the computer after completing these steps for Garmin Express to detect the device.
Adjusting the Security and Privacy Settings on macOS Ventura 13, macOS Sonoma 14, and macOS Sequoia 15
1. Select the Apple icon in the top-left corner of the desktop.
2. Select System Settings.
3. Select Privacy & Security.
4. Select Files and Folders
5. Select the check mark next to Garmin Express to expand it
6. Enable Removable Volumes
7. Select Quit & Reopen if prompted
Related
