Fusion® RA210 Manual Software Updates
Fusion RA210 Marine Stereo software version 6.50.129
as of April 2, 2025
Download (136.62 MB)
View installation instructions
Notes:
- This firmware release also contains updates for DAB+ accessories and NRX remote controls.
- NRX Series Remote 1.02.82
- DAB+ Module 1.06
- DAB+ Tuner 6.06
- USB Flash Drive: Ensure the USB Flash Drive is formatted to FAT32.
- Accessory software updates (MS-NRX Series/MS-DAB100A): Once the stereo is updated the connected accessory MUST be updated from the update menu to be compatible with your Fusion Entertainment System.
Change History
Changes made from version 6.40 to 6.50:
- Added numeric comparison to Bluetooth paring.
- Other improvements and bug fixes.
Changes made from version 6.30 to 6.40:
Changes made from version 6.20 to 6.30:
- Added support for software updates from Garmin Express
- Fixed an issue that could cause the device to reboot when using the Tuner source.
Changes made from version 6.10 to 6.20:
- Digital Signal Processing improvements
- Other bug fixes and improvements
Changes made from version 6.00 to 6.10:
- User interface performance improvements
Changes made from version 5.90 to 6.00:
- Changes to the way radio presets are displayed for AM, FM & DAB. Station names are now included.
- Other bug fixes and improvements.
Changes made from version 5.80 to 5.90:
- General improvements and bug fixes.
Changes made from version 5.70 to 5.80:
Changes made from version 5.50 to 5.70:
- Updated loudness curves.
- Updated splash screens.
- Added zone and device name suggestions.
- Added confirmation when deleting presets.
- Modified volume limit display.
Changes made from version 5.40 to 5.50:
Changes made from version 5.10 to 5.40:
- Added NMEA 2000 Speed vs Volume feature.
- Added Keep Volume ratios.
- Added Mono Audio setting.
- Added Zone Gain setting.
- Adjusted sub-woofer volume curve.
- Added crossover enabled DSP setting.
Changes made from version 5.00 to 5.10:
- Bluetooth source improvements.
Installation Instructions
- Download the update file to your PC/Laptop.
- Extract the zip file to a USB flash drive (format FAT32). A folder named Garmin will be created on the flash drive.
- Connect the USB Flash Drive to the USB Port of the stereo.
- Go to the settings menu and select >Update>Stereo and confirm Yes. The update will run and the stereo will reboot when complete.
- The accessories DAB+ and NRX remote can now be updated from the update menu if required.
