How Do I Enable a Data Field Downloaded from Connect IQ To My Watch?
After downloading and installing a Data Field from the Connect IQ™ Store, you will need to take some extra steps on your watch to enable this for your activities.
NOTE: Not all Connect IQ Data Fields may be compatible with all activity profiles. You can only use up to 2 Connect IQ Data Fields at a time. Exact instructions on how to change your data fields may vary by model. If needed, refer to your owner's manual and search "Customizing Data Fields."
  1. On the watch, access the activity list.
    Red arrow pointing to the Run profile
  2. Select the activity profile you want to enable this Data Field for, such as Run.
    Wait for GPS Run
  3. Select Settings.
    Arrow pointing to settings.
  4. Select Data Screens.
    Red arrow pointing to Data Screens
  5. Select Screen 1.
    Red arrow pointing to Screen 1
  6. Change Layout to 1 Fields.
    Red arrow pointing to Layout 1 Fields
  7. Select Edit Data Fields.
    Red arrow pointing to Edit Data Fields
  8. Select the current field.
    Red arrow pointing to screen
  9. Select ConnectIQ Fields
    Red arrow pointing to ConnectIQ Fields
  10. Select the Data Field you downloaded from Connect IQ.
    Red Arrow pointing to a downloaded Connect IQ Data Field
  11. Start your activity or repeat steps for other activity profiles.
Related
