Xero C1 Pro Chronograph Placement and Mounting
Placement and Mounting Considerations
Point the radar (the flat side with the Garmin logo opposite the screen) in the direction of fire. The unit should be to the side (left or right) of the rifle or bow, or below the barrel of a pistol. It is not affected by muzzle brakes or compensators.
NOTE: Always ensure you position the chronograph so it is not directly exposed to ejecting cartridge cases, muzzle blast, or other other hazards that may damage the chronograph. Also ensure it is within 5-15" of the muzzle or bow where the arrow is released.
There is no need to enter a manual position offset, the Xero C1 Pro chronograph uses an advanced algorithm that does not need position input to get true muzzle velocity.
If there are other electronic devices nearby the Xero C1 Pro chronograph automatically checks for interference and switches to a clean channel when needed, there is no need to set a channel manually. This includes interference from other radars, not just other Garmin radar-based devices.
Anything that covers or partially obscures the radar face of the chronograph can degrade or prevent the chronograph from recording shots accurately.
Mounting
The Xero C1 Pro Chronograph does not require mounting to your firearm or bow, it sits on a tripod with the radar facing in the direction of fire and located within 5-15 inches of your muzzle or where the arrow/bolt leaves the bow.
Xero C1 Attachment
While Garmin did not specifically design or test the use of this product mounted to a rifle, aftermarket manufacturers have tested the device mounted to a variety of rifle calibers and the Xero C1 Pro chronograph has worked without issue. Garmin does not warranty the product when used in a manner outside of the design content.
Related
