Starting a New Course Mid-Ride on My Edge
Most models of Edge® cycling computers have the ability to change the navigation course while the timer is still going. Select your model from the list below to view the steps.
Edge 130 | Edge 130 Plus
These steps are based on your timer already running and a course already having been selected on the device.
  1. Press and hold the top right button.
  2. Select Main Menu.
  3. Select Navigation.
  4. Select Courses.
  5. Select the course you are wanting to use.
  6. Select Ride.
Your course will now be active within this activity.
Edge 510 | 810
  1. Tap the screen to bring up the border menu.
  2. Select Magnifying glass Icon
  3. Select Courses
  4. Select Stop Course.
  6. Select Ride.
Edge 520 | Edge 520 Plus | Edge 530 | Edge 540 | Edge 540 Solar | Edge MTB
  1. Press the back button (bottom right) to return to the home screen.
  2. Select Navigation.
  3. Select Courses.
  4. Select the course you are wanting to use.
  5. Select Ride.
  6. Select Yes or No to navigate to the beginning of the course.
Edge 820 | Edge 830 | Edge 840 | Edge 840 Solar | Edge 1030 | Edge 1030 Plus | Edge 1040 | Edge 1040 Solar | Edge 1050
  1. Tap the screen to pull up the menu border.
  2. Select Edge Home Icon at the bottom of the screen.
  3. Select Navigation Button option.
  4. Select Courses.
  5. Select Saved Courses.
  6. Select the course you are wanting to use.
  7. Select Ride.
  8. Select Checkmark Icon.
Once this is done you can either route to the beginning of the course, or start riding from there as you normally would when starting a course.
Edge 1000
  1. Bring up the Home Screen.
  3. Select Edge Courses Icon.
  5. Select Ride.
  6. Select Checkmark Icon.
Edge Explore | Explore 820 | Explore 1000
  3. Select Edge Courses Option.
  4. Select Saved Courses.
  6. Select Ride.
  7. Select Checkmark Icon.
Edge Explore 2
  4. Select Courses.
  6. Select Ride.
