(2021) Service Bulletin 2193: G5 Airspeed Calibration
PRODUCTS AFFECTED:
Garmin G5 Electronic Flight Instruments purchased or installed since May 2021 listed in the link below are affected.
https://support.garmin.com/en-US/aviation/faq/hCwRzXXaMS8L6yQ2tW80w7/
NOTE
Serial numbers can be checked in Configuration Mode.
To enter configuration mode and view the serial number:
- Hold down the knob while applying power to the G5.
- Select Device Information.
- Select SFD, SFD1, or SFD2.
DESCRIPTION:
This service bulletin contains instructions to return the affected product to Garmin.
INSTRUCTIONS:
If the G5 product is affected:
- For certificated aircraft, contact your local Garmin Aviation Dealer for an RMA.
- For experimental aircraft, contact Garmin Product Support.
Make a logbook entry indicating compliance with Garmin Service Bulletin 2193.
COMPLIANCE:
Mandatory
PURPOSE:
Some G5 Flight Instruments may show an incorrect airspeed.
