Sharing Routes and Tracks from a zūmo XT2 with Other zūmo Users
You can share a route or track you have created with another zūmo® user two ways: from a track log, or from a saved route.
Sharing Data between zūmo® XT2 GPS Navigator Users
To Create a Route to Share from a Track Log on your zūmo XT2:
1. Select Apps
2. Select Tracks
3. Select a Saved Track
4. Select the wrench icon
5. Touch Convert to Route
6. Touch the preferred route direction
7. Name the route and touch Done
The track log will now appear in the Explore library as a route. To share the route, proceed to the following steps.
To Share a Saved Route on you zūmo using a Memory Card:
  1. Insert a microSD card into the zūmo
  • You may need to remove the zūmo from power, press and hold the power button, and select Off to restart the device in order for the microSD card to be recognized.
  2. Touch Explore
  3. Select the arrow icon and scroll down to Routes
  4. Select the desired route(s)
  5. Select the Wrench icon
  6. Select Share
  7. Touch Memory Card
  8. Name the route and touch Done
The receiving device should give a prompt to import the route after turning on the device with the SD card inserted.
To Send a Route from your zūmo to the the Tread™ App for Sharing from your Phone
  1. Select Apps
  2. Select Routes
  3. Select
  4. Select Share
  5. Select one or more routes
  6. Select Share triangle icon
  7. To share a route using the Tread app, select Garmin Tread.
  9. Touch OK
10. Open the Tread App on your phone or tablet
11. Select Share
12. Select the app you want to use for sharing the GPX file
Related
