On the watch, press START to access the activity and app list.
Select Connect IQ™ Store.
Select Must Haves.
Scroll to and select Deezer.
Press START to confirm and install the app.
Once the Deezer app finishes installing you are ready to move to Step 2.
If the Deezer app is not listed under recommended apps, it can still be installed via the Connect IQ store app or the Connect IQ store on the web using the steps below.
Manually Installing the Deezer App Using the Connect IQ Store App
You can install Connect IQ app content to your watch by following the instructions in Installing Connect IQ Content Using the Connect IQ Store App.
Manually Installing the Deezer App Using the Connect IQ Store on the Web
Select the following link to download the app: Deezer Connect IQ App.
Select
button.
If prompted, sign into your Garmin account.
Select your watch to download the app.
Acknowledge any app permission requests.
- Message should indicate that the app will be installed during the next sync. If this does not occur automatically, below are options to sync your watch:
To sync via Bluetooth: Be in range of your paired smartphone, open the Garmin Connect app, and select
to sync.
To sync via Wi-Fi: Be in range of your previously set up Wi-Fi network, and hold Menu on the watch. Select Connectivity > Wi-Fi > Wi-Fi Sync and wait while the watch connects and syncs.
To sync using the Garmin Express™ program: Connect the watch to a computer using the supplied power/data cable. Open the Garmin Express program. Sync will automatically occur once the watch is detected.
