Benefits of Pairing an inReach Handheld Device to a Garmin Watch
Many Garmin® handhelds with inReach® satellite communication capabilities can be paired with compatible Garmin watches to bring the most commonly used inReach functions to your watch.
How the Watch and inReach Handheld Work Together
With a watch paired to an active handheld with inReach technology, inReach functions can be controlled from the watch using the inReach Remote widget. This allows the user to stay in touch with the inReach handheld at a glance while keeping the handheld secured high on the body or backpack for optimal sky view and transmission. For more information on the inReach Remote widget see Using the inReach Remote Widget on Garmin Watches.
Integration With the Garmin Explore™ App
The GPSMAP® 66i, 67i, 86i, 86sci, Montana® 700i, 710i, 750i, and 760i outdoor handhelds, and many Garmin watches are compatible with the Garmin Explore app and website. With both devices on the same Garmin Explore account, all your data (waypoints, tracks, routes, and activities) can be stored in one place and synced between devices making trip planning and post-trip analysis simpler. With the watch and handheld paired to the Garmin Explore app, you can:
Use Collections to gather and sync groups of data to multiple devices.
Plan detailed routes in the Garmin Explore app then sync to paired devices.
Sync data from devices to the Garmin Explore app offline via Bluetooth — no cell or data coverage needed.
For more information about using the Garmin Explore app, see Related.
Device Compatibility
If you are considering adding a watch or handheld with inReach capability to your gear kit, or already own one device or the other and wondering what is compatible, refer to the following FAQ to check compatibility with inReach Remote.
