User Data Limitations of the GPSMAP 276Cx
When sending or creating files for a GPSMAP® 276Cx handheld, keep in mind the following limitations:
2,000 GPX files
10,000 waypoints
No limit on geocaches (outside of max number of GPX files supported and memory available)
250 routes, 250 points per route; 50 points turn-by-turn routing
250 saved tracks
2,000 archive tracks
20,000 points per track
100 custom map tiles
BirdsEye Imagery files - no limitation other than available memory
Mapping segments 15,000
For more information on map segments, see Related.
Each GPX file can contain a mixture of waypoints, geocaches, routes and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on the device.
When utilizing routes, only 50 points can be used for turn-by-turn navigation on roads or trails.
