Installing the Panoptix LiveScope Perspective Mode Mount
When installing the Panoptix LiveScope Perspective Mode Mount, it is important to use the screws that come with the mount. Do not use the transducer mounting screw from the previous mount. Using a different screw can over compress the transducer to where it will not move properly. If the screw is not torqued enough, it can get too loose and fall off.
