eTrex® SE
eTrex® Solar
eTrex® Touch 35 | eTrex® Touch 35t
Foretrex® 601 | Foretrex® 701 Ballistic Edition
Foretrex® 801 | Foretrex® 901 Ballistic Edition
GPSMAP® 64s | GPSMAP® 64sc | GPSMAP® 64st | GPSMAP® 64sx | GPSMAP® 64csx
GPSMAP® 65 | GPSMAP® 65s
GPSMAP® 66i | GPSMAP® 66s | GPSMAP® 66sr | GPSMAP® 66st
GPSMAP® 67 | GPSMAP® 67i
GPSMAP® 86i | GPSMAP® 86s | GPSMAP® 86sc | GPSMAP® 86sci
GPSMAP® 276Cx
Montana® 700 | Montana® 700i | Montana® 710| Montana® 710i | Montana® 750i | Montana® 760i
Oregon® 700 | Oregon® 750 | Oregon® 750t
Rino® 750 | Rino® 750t | Rino® 755t
Smart Notifications on a Garmin Outdoor Handheld
Some outdoor handhelds are able to pair to a smartphone or tablet through Bluetooth®.
This is helpful to be able to tuck your phone or tablet away and see what notifications it receives displayed on your Garmin device instead. For instructions on pairing, refer to your owner's manual.
Managing Smart Notifications
Many of the notifications that appear on the phone or tablet can be displayed on the handheld, such as emails/calls/texts received, calendar events, app alerts, etc.
Notifications can only be deleted from the phone or tablet.
You can manage which notifications show up on your handheld from within the settings of the Garmin Connect™ or Garmin Explore™ apps on Android or your phone/tablet settings on iOS.
NOTE: Some devices are compatible with both apps. If you use both apps, the notification settings within the Garmin Explore app and Garmin Connect app should be set to match one another.
Garmin Connect App
Open the Garmin Connect app.
Select More (bottom right).
Select Settings.
Select Smart Notifications.
From here, toggle to enable or disable all Smart Notifications or customize by selecting individual apps.
Garmin Explore App
Open the Garmin Explore app.
Select the profile icon in the top left.
Select App Settings.
Select Notifications.
From here, toggle to enable or disable notifications for All Applications or customize by selecting individual apps.
Swipe down from the top of the home screen.
Select the Settings Icon.
Select Battery.
Select App Launch.
Select individual or batch select apps, where auto, secondary and run-in-background settings can be disabled/enabled individually
NOTE: You will want to select Disable for Connect (and Explore, if installed) if you are selecting individual apps.
From the iOS device, touch Settings.
Under NOTIFICATION STYLE select the app you want to turn on or off.
Refer to your phone iOS version below and follow the steps.
iOS 12 and Newer
Under ALERTS:
Notification Center checked: Garmin device will display a notification for the selected app.
Notification Center unchecked: Garmin device will not display a notification for the selected app. This will also result in notifications no longer appearing in the phone's notification center.
iOS 11 and Older
Under ALERTS:
Show in History ON: Garmin device will display notification for selected app.
Show in History OFF: Garmin device will not display notification for selected app. This will also result in notifications no longer appearing in the phone's notification history.
