Garmin quatix 7X and quatix 7 Pro Flashlight Features
quatix® 7X and quatix® 7 Pro watches feature an LED flashlight with the ability to adjust brightness, strobe, color, and activity settings.
Using the quatix 7X or quatix 7 Pro Flashlight
Quickly pressing the LIGHT key twice will enable/disable the built-in LED flashlight, which is located above the display between the watch bezel and the band:
When the flashlight is activated, it will use the last flashlight setting that was selected (strobe and distress pattern excluded) .
Flashlight Settings for General Use
These settings are general use of the flashlight outside of activities. For settings during activities, see the section below.
- Press and hold LIGHT to access the Controls menu.
NOTE: If Flashlight is not in the Controls menu, you will need to add it to access the settings, see - Customizing the Controls Menu. - Select
- The following options will be available:
Activities and App Settings
In addition to the options listed above, the watch can also be customized to use different light modes during certain activities. For example, it can be set to automatically activate a strobe light when running after sunset.
To adjust these settings:
Hold UP/MENU
Select Activities & Apps
Select an activity
Select the activity settings
Select Flashlight Strobe, then select an option:
Status - Choose between Off, After Sunset, or On
NOTE: After Sunset will use the sunset time determined by the watch, and will continue until 30 minutes after sunrise
Mode - Choose between Blink, Pulse, Beacon, Blitz, or Cadence
