"There was a problem communicating with the Garmin device" Error in BaseCamp
BaseCamp™ software or the device may display the error "There was a problem communicating with the Garmin device" if corrupt data is encountered on a connected device.
Corrupted Files That may Cause This Error Include the Following File Types:
  • GPX (Waypoints, Tracks and/or Geocaches).
  • JNX (Birdseye files).
  • JPG (Pictures).
Select an operating system for steps to resolve
Windows
If there is a corrupt file on the device, the Windows version of BaseCamp software also displays the error "An error occurred while reading the following file(s)", indicating which file is corrupt.
To Resolve This Error, Delete the Corrupt File Indicated:
  1. Press Windows + E
  2. Click This PC (Windows 10 and 11 only)
  3. Open the Garmin drive
  4. Open the Garmin folder (not all devices require this step)
    • Select Internal Storage first on some devices.
  5. Open the GPX, JNX (or BirdsEye), or JPG folder
  6. Delete the file indicated from the error in BaseCamp software
This should resolve the issue. If the issue persists, verify that the Garmin device is communicating with Windows applications correctly. Instructions for verifying that the device is communicating properly can be found in Related Content.
After deleting the corrupt file or files, BaseCamp software will not display the communication error.
Mac
The Mac OS X version of BaseCamp software only displays the error "There was an error communicating with the Garmin device". The error will not indicate if a corrupt file is causing the issue.
First, verify the Garmin device is communicating with Mac applications.  Instructions for verifying that the device is communicating properly can be found in Related Content.
If the error is still being displayed, delete the GPX, JNX (or BirdsEye), and JPG folders on the device. Because this may delete saved user data, pictures, and BirdsEye images from the Garmin device, first save a copy of these folders to the desktop:
  1. Open Finder
  2. Click Go in the menu bar
  3. Click Computer
  4. Open the Garmin drive
  5. Open the Garmin folder (not all devices require this step)
  6. Click and drag the GPX, JNX (or BirdsEye), and JPG folders to the desktop (This may take a long time if there is a lot of data)
  7. After the folders have been copied to the desktop, move these folders on the Garmin device to the Trash
  8. Empty the Trash
Open BaseCamp software to test that the device communicates properly.
If the error message does not appear, one or more of these folders contains corrupt data that is causing the error in BaseCamp software.
To Test Which Folder Contains the Corrupt Data:
  1. Open the Garmin drive in Finder
  2. Open the Garmin folder (only do this if this was required when originally copying the folders to the desktop)
  3. Click and drag the JPG folder from the desktop to the device
  4. Open BaseCamp software
If the communication error shows up, there is a corrupt file in the folder and the contents of this folder should be deleted to resolve the issue.
If the communication error does not appear, this folder does not contain corrupt data and can be kept on the device. Repeat the steps above for the remaining JNX (or BirdsEye) and GPX folders.
Once the corrupt files are removed from the device, the error message will no longer appear in BaseCamp software.
NOTE: It is recommended that a Windows computer be used for the following devices. Files cannot be viewed when connected to a Mac computer.
    • Arctic Cat G8 Display
    • Camper 780 & Traffic caravan and motorhome sat nav
    • Camper 785 & Traffic caravan and motorhome sat nav with camera
    • Camper 795 caravan and motorhome sat nav
    • Camper 890 caravan and motorhome sat nav
    • Camper 895 caravan and motorhome sat nav
    • Camper 1090 caravan and motorhome sat nav
    • Camper 1095 caravan and motorhome sat nav
    • CamperCam 795 motorhome sat nav with built-in dash cam
    • CamperVan caravan and motorhome sat nav
    • dēzl™ 780LMT-S GPS navigator
    • dezl™ LGV500 and dēzl™ OTR500 GPS navigators
    • dēzl™ LGV610 and dēzl™ OTR610 GPS navigators
    • dēzl™ LGV620 and dēzl™ OTR620 GPS navigators
    • dēzl™ LGV700 and dēzl™ OTR700 GPS navigators
    • dēzl™ LGV710 and dēzl™ OTR710 GPS navigators
    • dēzl™ LGV720 and dēzl™ OTR720 GPS navigators
    • dēzlCam™ LGV710 and dēzlCam™ OTR710 GPS navigators with camera
    • dēzlCam™ LGV725 and dēzlCam™ OTR725 GPS navigators with camera
    • dēzl™ LGV800 and dēzl™ OTR800 GPS navigators
    • dēzl™ LGV810 and dēzl™ OTR810 GPS navigators
    • dēzl™ LGV820 and dēzl™ OTR820 GPS navigators
    • dēzl™ LGV1000 and dēzl™ OTR1000 GPS navigators
    • dēzl™ LGV1010 and dēzl™ OTR1010 GPS navigators
    • dēzl™ LGV1020 and dēzl™ OTR1020 GPS navigators
    • dēzlCam™ 785 LMT-S GPS navigator with camera
    • Garmin Catalyst™ Driving Performance Optimizer
    • Garmin Drive™ 53, Garmin Drive™ 53 & Traffic, and Garmin Drive™ 53 & Live Traffic GPS navigators
    • Garmin DriveCam™ 76 GPS navigator with camera
    • Garmin DriveSmart™ 55 & Traffic GPS navigator
    • Garmin DriveSmart™ 65 & Traffic GPS navigator
    • Garmin DriveSmart™ 65 with Amazon Alexa GPS navigator
    • Garmin DriveSmart™ 65 Traveler's Edition GPS navigator
    • Garmin DriveSmart™ 66 GPS navigator
    • Garmin DriveSmart™ 71 GPS navigator
    • Garmin DriveSmart™ 76 GPS navigator
    • Garmin DriveSmart™ 86 GPS navigator
    • Kawasaki RIDGE 8" Tread Display
    • Overlander® GPS navigator
    • RV 780 & Traffic RV navigator
    • RV 785 & Traffic RV navigator with camera
    • RV 795 RV navigator
    • RV 890 RV navigator
    • RV 895 RV navigator
    • RV 1090 RV navigator
    • RV 1095 RV navigator
    • RVcam 795 navigator with built-in dash cam
    • Tread®, Tread® - Base Edition, Tread® 2, Tread® - Overland Edition, Tread® XL - Overland Edition, Tread® - SxS Edition, Tread® XL - Baja Chase Edition, and Tread® XL - Baja Race Edition GPS navigators
    • zūmo® XT and zūmo® XT2 GPS navigators
See Automotive Device Compatibility with Garmin Mac Applications on macOS for information on viewing files on these devices.
Related
