Incomplete Text Message Notifications Displaying on My Garmin Device
When your Garmin® device is paired with a smartphone, text messages can be viewed directly on the device. The level of message detail will be based on the smartphone or message app settings. If you are not able to view the full text message, you will need to adjust the settings.
NOTE: The following are general instructions for Android™ systems. Your phone setup may vary depending on your messaging app and operating system. Some phone models may not support all of the options below. For specific instructions consult your owner's manual, phone manufacturer, or carrier.
Messaging Application Settings Instructions
  1. Open your messaging application on your smartphone.
  2. Select the Menu.
  3. Select Settings.
  4. Select Notifications (some phones skip this step).
  5. Select In-app notifications settings (some phones skip this step).
  6. Locate and enable Preview or Preview Message.
Phone Settings Instructions
  1. Open your phone settings.
  2. Locate notification settings (sometimes Sound & Notifications).
  3. Locate the Notifications heading.
  4. Check the Device Lock settings (they may be set to show, hide, etc.).
Garmin Device Privacy Settings
NOTE: Not all Garmin models will have the Privacy setting feature for notifications. Refer to your owner's manual.
  1. Access your Garmin Device's Settings Menu.
  2. Select the Gear icon for settings.
  3. Select Connectivity/Phone.
  4. Select Notifications.
  5. Select Privacy, then select a privacy preference:
    • Off: This will allow notifications and its content to display on your watch.
    • Action: This will allow notifications but not its content to display. Perform an action on your watch by tapping the notification to view the content. If your display has a timeout, you may need to press a button to activate the display prior to taping the notification.
    • Gesture: This will allow notifications but not its content to display. Perform a gesture (rotate your wrist toward your body to view the device) to view the notification content.
Related
