TopoActive Map Segments
Garmin's TopoActive map products that are currently available as a download are made up of sections called map segments. Each device can only hold a certain number of map segments which can cause issues if installing multiple regions of the TopoActive maps or installing them alongside other mapping products. For a coverage map of the regions and the number of map segments found in each, see the information below.
North America
TopoActive North America data includes multiple files and a total of 926 map segments.
  • TopoActive NA, US 2024.10: 358 map segments
  • TopoActive NA, Canada/Alaska 2024.10: 305 map segments
  • TopoActive NA, Middle America 2024.10: 82 map segments
  • DEM Map North America 2024.10: 189 map segments
TopoActive North America 2023.10
Europe
TopoActive Europe data includes multiple files and a total of 784 map segments
  • TopoActive EU, East 2024.10: 218 map segments
  • TopoActive EU, West 2024.10: 257 map segments
  • TopoActive EU, Central 2024.10: 242 map segments
  • DEM Map Europe 2023.10: 75 map segments
TopoActive Europe 2023.10 Coverage
South America
TopoActive South America data includes multiple files and a total of 371 map segments.
  • TopoActive South America 2024.10: 250 map segments
  • DEM Map South America 2024.10: 239 map segments
TopoActive South America 2023.10
Africa
TopoActive Africa, North 2024.10: 266 map segments
TopoActive Africa, South 2024.10: 282 map segments
TopoActive Africa Coverage
Australia/New Zealand
TopoActive Australia/New Zealand data includes multiple files and a total of 177 map segments.
  • TopoActive Aus/NZ 2024.10: 131 map segments
  • DEM Map Aus/NZ 2024.10: 247 map segments
OpenStreetMap Coverage Details
OpenStreetMap (OSM) is developed and added to by community mappers around the world. OSM is a highly detailed dataset. In many rural areas of the world, OSM has medium-to low-detailed data. Features are added and edited by community members with local knowledge. Coverage of features may vary and includes geographic locations, place names, landmarks, points of interest, hydrographic features, and land-use/land cover. OSM is an open data source. OSM also includes an open data source elevation dataset. The scale is not consistent because the OSM data is Volunteered Geographic Information. Scale detail can vary from 1:24K or better in major urban areas to much higher scales in more rural areas.
Utilizing the appropriate number of map segments for your device can help ensure your map functions correctly. For more information on the number of map segments that can be stored on a device, visit your specific model's product page on Garmin.com and review "Map Segments" on the Specs tab.
OpenStreetMap Terms and Conditions ~ Certain Garmin products include OpenStreetMap data. Garmin OpenStreetMap products are not subject to the End User License Agreement (EULA) terms, but rather are subject to the Terms and Conditions set forth below.  OpenStreetMap data is copyright OpenStreetMap contributors and is subject to the Open Database license. Any rights in individual contents of the OpenStreetMap data are licensed under the Database Contents License
No Warranty ~ Garmin OpenStreetMap products are provided to you “as is,” and you agree to use it at your own risk.  Garmin and its licensors, including the licensors, service providers, channel partners and suppliers, and affiliated companies of Garmin and its licensors, make no guarantees, representations or warranties of any kind, express or implied, arising by law or otherwise, including but not limited to, content, quality, accuracy, completeness, effectiveness, reliability, merchantability, fitness for a particular purpose, usefulness, use or results to be obtained from the Garmin OpenStreetMap products, or that the content or server will be uninterrupted or error-free. The Garmin OpenStreetMap products are intended to be used only as a supplementary travel aid and must not be used for any purpose requiring precise measurement of direction, distance, location or topography. Garmin makes no warranty as to the accuracy or completeness of the map data in the OpenStreetMap products.
Related
