Navigating to a Destination on the eTrex Legend H and Vista H
Navigating to a Waypoint on the eTrex Legend® H and eTrex Vista® H Outdoor Handhelds
- Press and hold Menu/Find to display the Find menu.
- Use the Thumb Stick to highlight 'Waypoints' and then press it in. By default, the list shows only those nearest to your current location. Press Menu/Find to view the options list.
- Use the Thumb Stick to highlight the desired waypoint and then press it in to display the information page.
- With the on-screen 'Go To' button highlighted, press the Thumb Stick in to begin navigation to the waypoint.
Navigation to a Location Using Find By Name
- Use the Thumb Stick to highlight the icon for the type of item you want to search for, and then press it in. By default, the list shows only those nearest to your current location. Press Menu/Find to view the options list.
- Use the Thumb Stick to operate the on-screen keypad, and enter the name of the location you want to find. When the Find list contains a match, select OK.
- Use the Thumb Stick to highlight and select the location item from the Find list.
The item's information page opens, allowing you to save the item as a waypoint, show the item on the map, or navigate to the item. - With the on-screen 'Go To' button highlighted, press the Thumb Stick in to begin navigation to the location.
Stopping Navigation
- While viewing Map page, press Menu/Find.
- Use the Thumb Stick to highlight 'Stop Navigation' and then press it in.
