Range Finder Accuracy and Maximum Range for Xero X1i
The Xero X1i built-in rangefinder is very accurate. The rangefinder will display the adjusted distance range in yards or meters depending on what is selected during the initial setup. If you would like to view a more accurate representation of the distance ranged, change the unit settings to decimal precision. Instructions can be found in the owner's manual.
The decimal precision measurement will adjust the rangefinder to show the adjusted distance range to the 1/10th of a yard or meter.
Recommended Maximum Effective Range for Xero X1i
The maximum effective recommended range for the bow sight is 250 yards/229 meters on a non-reflective target or up to 500 yards/460 meters on a reflective target. A non-reflective target is something that does not reflect light, like an animal or a tree. A reflective target will reflect light, examples would be metal, glass and sometimes wet rocks.
Please keep these features and limitations in mind when using the Xero X1i to range targets.
